Build ADT Dataset
A method of building “ADT Dataset” is introduced to add device configuration files and CLI commands as links into dataset column, serving as data source for intent creation, intent decoding, intent replication, and intent execution. The ADT dataset can be created by using the following four types of data source.
Table 1 - Data Source for Creating ADT Dataset
Data SourceDescription
BenchmarkUse CLI commands from benchmark task results to create ADT dataset column.
Imported FilesUse device configuration files and CLI command data from external files via Import File Wizard to build ADT dataset, then the imported command data together with corresponding device data will be added to ADT.
Manually Retrieved DataManually add commands to the ADT dataset or select commands in the intents of an ADT. Then, these commands can be manually retrieved later.
Update by IntentUse diagnosis logic “Update ADT Dataset” in the intent to update or create the ADT dataset. The data of this type can only be added by intents and cannot be manually added/deleted.
