R12.1 Project-2025/11/05
Map Page Settings
The Map Page Settings dialog box is a central place where you can set various options for map pages. You can go to Map > Map Page Settings from the Map Toolbar to set the map page options.
User Preferences
To access these settings, click your profile icon and select User Preferences from the dropdown menu.
In the User Preferences panel, you can configure how the map behaves during interaction. You can:
  • Double-click behavior: Choose what happens when you double-click a device—for example, display device details.
  • Zoom control: Enable zooming with the mouse wheel only when the Ctrl key is pressed.
  • Port layout optimization: Automatically adjust the position of ports when moving devices on the map.
  • Default Runbook Template: Select a default runbook template to apply when creating new runbooks.
Map Page Settings Attributes
The Map Page Settings section includes the following configurable attributes:
Table 1 - Map Page Settings
AreaContentExplanation
View Options for Data Unit Data Unit
Includes device hostname, interface name, Device Note and the following:
  • Device/Link Position — where device properties can be defined in data view templates. See Creating a Data View Template for details.
  • Overflow Position — shown as under a device icon on a map.
  • Other Draw Shapes — the shapes drawn on a map. See Map Stencil for more details.
Display RatioIndicates the threshold of zoom controls for displaying a corresponding data unit on a map.
Zoom StepIndicates the zoom controls changed by each zoom-in or zoom-out action. See Browse Device Data on Map for more details.
Hide media connected with two topology links onlyHide the media with only two topology links in total in the database, not the media with only two topology links drawn on the map.
Graphical user interface  Description automatically generated with medium confidence
Interactive & Backend Auto Link Settings
Default Auto Link:
  • IPv4 L3 Topology
  • IPv6 L3 Topology
  • L2 Topology
  • L3 VPN Tunnel
  • Logical Topology
  • L2 Overlay Topology
See Topology Type for details.
Link Option Between Two Devices:
  • Exclude Management Interface
Excludes management links from the map while using the auto-link function.
Information Note: This option has a dependency on the execution of the built-in plugin Identify Management Interfaces through the basic system benchmark task.
Extend Links
  • A Random Link
  • All Found Links
Defines how many links are automatically drawn between devices.
Auto Link after Update Map
  • Always auto-link all devices
Auto-link all devices after the map is updated
Apply to Other MapsEnables applying the auto link setting to existing maps/map pages
Device View on Expanded StyleA picture containing diagram  Description automatically generatedOne device type that is suitable for a Layer 2 topology. You can point to a port or click a link to view its detailed information.
Interface Highlight Mode
Highlight Link & Port
Highlight both links and ports.
Diagram  Description automatically generated
Only Highlight LinkHighlight link.
Only Highlight PortHighlight port.
Enable Tip Window of Switch PortEnable Tip Window of Switch PortSet to give tips for the switch port.
Hide the Author and Time in the Note
Set to make the Author and Time invisible in the Note.
Map Background Color
  • Map Background Color
  • Set Color
Set the background color for a map.
Information Note: For some map page settings, you can check Set as Default to keep the current settings as the default settings.
Information Note: For some map page settings, you can apply the setting to other maps. Click Apply to Other Maps, then click one of the three map categories (Common Map, Device Group Map, Site Map) to select the maps to apply the setting.
See Also:
Auto Link
