Viewing Devices Exceeding License Limit
If you need to view the devices discovered after exceeding the license limit, go to Domain Management > Data Accuracy Resolution > other.
Under the folder Devices Exceeding License, the Foundation category and the WAP category are provided to record devices discovered after the license limit is exceeded.
Foundation Table
The Foundation Table lists all the devices exceeding the license limit in the foundation module.
On the Foundation Table, you can perform the following actions:
  • Refresh the table: Click Refresh at the upper-right corner of the left pane to refresh data in the table.
  • Filter messages: Enter the keyword at the upper-right corner of the page to search for devices in the table.
  • Re-discover a device:  Select one device or press Ctrl/Shift to multi-select multiple devices, right-click on them and select Discover Selected Devices in the drop-down list to re-discover the device.
    TableDescription automatically generated
  • Delete an Item from the Table: Select one device or press Ctrl/Shift to multi-select multiple devices, right-click on them and select Delete from Table in the drop-down list to delete the device.
  • Export to CSV File: Click on the icon on the top right corner of the page to export the devices exceeding the node limit in CSV format to the local machine.
WAP table:
The WAP Table lists all the devices exceeding the license limit in the WAP module.
Information Note: The WAP table supports the same actions as the Foundation Module Table.
