R12.1-2025July30
Discover over Node Limit
The discovery process will continue even when the node limit is exceeded. The devices discovered after exceeding the license limit will be recorded and presented in the form of a table.
You can specify the maximum percentage by which the node limit can be exceeded. By default, it is 0%, and you can change it from 0% to 100000%. For example, if the percentage is set to be “100%”, the number of discovered devices can reach two times the license limit.
Information NotesThis percentage only applies to traditional network devices.
You can check the number of nodes exceeded by clicking on License Details after discovery is finished.
