Allowing Exceed of License Limit
Sometimes it is hard to determine the amount of license required to discover your network due to the expansion or change of the network. Therefore, even if you do not have enough license nodes for the domain, NetBrain allows you to discover the network devices over the node limit. Go to Domain Management > Discover > Advanced Options to set relevant settings (e.g., you can set that the devices are discovered if 10% of license nodes are over license limit). The devices discovered after exceeding the license limit are not directly added to your domain, but they will be recorded in a table to help decide the extra license needed.
