R12.1 Project-2025Sep08
Use the Data View Template
On-Demand Data Overlay
- From the NetBrain Desktop Management UI, open the desired map.
- In the Dynamic Data View tab, search for “[Solarwinds] Device, Interface and Syslog Monitoring Data”.
- In the Preview – Data View Template dialog, click Apply.
- On the NetBrain map, confirm that the Cache/Live data source switch is set to Live.
- Confirm that the objects (devices and interfaces) are properly instrumented with the expected Solarwinds data.
Note: Overlay of the Solarwinds data may take seconds-to-minutes to complete refresh depending on the number of devices on the map.
Schedule Data Import from Solarwinds
- In the NetBrain Domain Management page, navigate to Schedule Task.
- Click on Schedule Data View Template/Parser, then click on Add Task.
- In the Add Task dialog, specify the frequency for which to import device and interface data from Solarwinds.
- Click on the Device Scope tab, then click “Device Group” radio button. Add each device group created as part of the integration to limit the device scope of the available devices.
- Click on the Select Data View Template/Parser tab, click on Add and search for [Solarwinds] Device, Interface and Syslog Monitoring Dat
- Click Submit to create the scheduled task for Solarwinds data import to NetBrain.
Note: The Solarwinds data will not be available on the map until after the first time that the scheduled task has completed execution.
Troubleshooting
If there are any problems encountered during the deployment or integration of NetBrain with Solarwinds, contact NetBrain Support at [email protected].
