R12.1 Project-2025Sep08
Configure SPOG Link
Update SPOG Link Generic Variable:
- Navigate to the NetBrain Generic Variable.
Click the start menu
> Single Pane of Glass URL > Generic Variable
- Right-click on Solarwinds and select the Edit button to change the Value to the actual Solarwinds endpoint (For example: “http://192.168.28.155:8000”)
- Click OK to save the change.
