Use NetBrain Download
NetBrain Download is primarily designed for users with the “Shared Resource and File Management” privilege to check Configure Orchestration Files and download assets by executing corresponding files.
The following major operations can be performed in NetBrain Download:
- Manage Libraries.
- Install/reinstall task: Install/reinstall tasks by executing the command line scripts for installation.
- Uninstall Task: Uninstall tasks by executing command line scripts for uninstallation.
- Check Prerequisite: Automatically check if the prerequisites for installing tasks are satisfied during installation, and the results will be displayed in the execution log.
- Create and Download Library Files in NetBrain Download
- Import Library to NetBrain Download
- Fix Empty Cells with Retrofit File in NetBrain Download
Note: The dependency relationship of a task is displayed in the NetBrain Download UI.
