Use ADT Dataset for Intent Decoding
To use the ADT dataset for intent replication, you should install the NIT and decode it first. Decoding NIT can be done using ADT dataset as data source. In the current version, ADT dataset is a type of data source for decoding intent in both the IBA Center and Auto Intent Wizard (Step 2).
Use Dataset for Decoding Intent in IBA Center
The following diagram shows the data source options for intent decoding in the IBA Center:
  • Use the ADT dataset in Decoding Settings to decode the intent once immediately after the intent is installed.
  • Use the ADT dataset in Decoding Settings to decode intent after the intent has been installed.
  • The current Baseline is provided as a data source for intent decoding.
Use Dataset for Decoding Intent in Auto Intent Wizard (Step 2)
Auto Intent Wizard offers a quick way of installing and decoding intent. Accordingly, the ADT dataset is introduced as a new data source type to achieve this goal.
  • ADT dataset can be used for Install & Decode (decode intent once) and Decode Now (manually decode intent after the intent has been installed).
  • The settings of using the ADT dataset for decoding intent are saved only after you apply the settings (clicking Install & Decode or Decode Now).
