Transfer Editing Rights
In addition to proactively releasing editing rights of a map or network dashboard, you can also transfer the editing rights to a specific user.
Transfer Editing Rights for a Map
- On the target map, click Map > Editing Rights on the map toolbar.
- Click Transfer Editing Rights on the prompted tip box.
- In the Transfer to field, specify the user who will get the editing rights.
- Click Transfer.
The selected user will receive a system notification and an email (if your email server is configured).
Note: You cannot transfer the editing rights of a site map or system device group map to an offline user. |
Transfer Editing Rights for the Network Dashboard
- On the target network dashboard, click the
icon from the network dashboard toolbar and select Editing Rights from the drop-down menu. - Click Transfer Editing Rights on the prompted tip box.
- Click Transfer.
