Supported Context Maps of vCenter Nodes
The following table outlines the available context maps of each vCenter node under different views.
Supported Context Maps under Hosts and Clusters View
Node Context Maps
Cluster
Four context maps are supported for this node:
  • ESXi Host to Layer 2 Neighbors displays the Layer 2 topology between each ESXi host of this cluster and its connected physical switches.
  • ESXi Host to Layer 3 Neighbors displays the Layer 3 topology of each ESXi host of this cluster and its gateway devices.
  • VM to Layer 2 Neighbors displays the Layer 2 topology between each VM of this cluster and its connected vSwitch, as well as the topology between the vSwitches and its up-link physical switches.
  • ESXi Host to VM displays each ESXi host of this cluster and Virtual Machines under the host.
ESXi Host
  • ESXi Host to Layer 2 Neighbors displays the Layer 2 topology between a host and its connected physical switches.
  • ESXi Host to Layer 3 Neighbors displays the Layer 3 topology of a host and its gateway devices.
  • VM to Layer 2 Neighbors displays the Layer 2 topology between each VM and its connected vSwitches and the topology between vSwitches and physical switches.
  • ESXi Host to VM/vSwitch displays the parent/child relationship between a host and vSwitches/VMs under the host.
Resource Pool
One context map is supported for this node:
  • VM to vSwitch displays the topology between each VM and its connected vSwitches and the connection between the vSwitches and its up-link physical switch.
VM
Three context maps are supported for this node:
  • VM to Layer 2 Neighbors displays the Layer 2 topology between the VM and its connected vSwitches and the topology between vSwitches and physical switches.
  • VM to Layer 3 Neighbors displays the Layer 3 topology between the VM and its gateway device.
  • VM to ESXi Host displays the dependency relationship between the VM and ESXi host.
Supported Context Maps under Networking View
Node Context Maps
Port Group
  • Port Group to Layer 2 Neighbors displays all VMs under this port group and the Layer 2 topology between the port group's vSwitch and physical switches.
VMSame as the context maps of the VM node under the hosts and cluster view.
VDS
Two context maps are supported for this node:
  • VDS to Layer 2 Neighbors displays all connected Layer 2 neighbors of this VDS.
  • VDS to ESXi Host displays the ESXi hosts that the VDS runs on.
Uplink Port Group
  • Uplink Port Group to Layer 2 Neighbors displays the topology between the Uplink Port Group and physical switches.
Distributed Port Group
  • Distributed Port Group to VM Neighbors displays the ports of this port group and their connected Layer 2 neighbors.
