Static Data View
The static data view is a layer-based structure to organize and display various network data. It includes the global data view and local data view:
  • Data view decodes static network design, enabling knowledge sharing and collaboration with ease.
  • Data view enriches data that can be visualized on a map and enables the dynamic map to serve as the single pane of glass for all network data. Users can select different data views based on different use scenarios.
cid:image001.jpg@01D3DD53.14745A30
Use Case
