Set Up Sites
A site is a geographical grouping of network devices, which can be used as device scopes, asset filters, and map/topology views. For example, you can divide your network into a hierarchy of sites based on country, state, city, region, and office location.
There 2 types of Sites:
  • Container Site () — A parent site that contains leaf sites and other container sites. No devices are directly nested under a container site.
  • Leaf Site () — A child site that contains devices. The devices can be added manually or searched dynamically. One device can only belong to a leaf site.
Site Manager is the central place where you can add new sites and edit existing sites.
Open Site Manager
  1. Click on the Desktop and log into Domain Management.
  2. Click Site to Open Site Manager.
Tip: Only one user can log into Site Manager at a time. You might receive a warning message if other people open the Site Manager
  1. In Site Manager, you can manage your sites by adding more sites, rebuilding sites, exporting sites, deleting sites, and more.
Information Tip: a given device can only be assigned to one leaf site, meaning that site members are exclusive for each site. If you wish to assign a given device to multiple sites for specific usage, please go to Device Group for more details.
Default Settings for a Map Page:
Note: The default settings do not impact the existing create map logic and they are only applicable when generating a map.
For the new site maps, default settings can be configured in Site Map Page Settings available under the Site Manager. To view the default settings:
  1. Open Domain Management and go to Site Manager.
  2. Click on the Site Map Page Settings at the bottom of the window.
