Search for Paths
Follow the steps below to search Paths:
  • Path name, application name
  • Source, destination
  • IP address or hostname of the hop device
    Information Note: When an IP address is entered in the source or destination field, you can perform a search using the associated device name as long as the IP address corresponds to a device within the domain.
  1. Press Enter. The search results are displayed with the matched keyword highlighted.
  2. Right-click the target path entry and then select Draw Path on Map.
    Information Note: You can also hover over the path in the IntelliSense and click Map to map the path directly.
    Information Note: If the path has not been calculated, the map will be blank.
