Path Technologies for Different Vendors
NetBrain dynamic path feature visualizes the forwarding of the packet and emulates the real packet forwarding process by looking up route tables in your live network and provides end-to-end visibility across any network path. Besides looking up route tables to find the next hop, It can also look into PBR, NAT, ACL, firewall policy and other traffic control technologies to ensure the correctness of a path.
This document introduces the vendors and device types that the system supports to parse in terms of the following special path technologies when calculating a path:
  • Policy
  • ACL
  • PBR
  • NAT
  • SNAT
  • MPLS VPN
  • IPsec VPN
  • GRE VPN
  • MPLS TE
  • Fabricpath
  • OTV
  • VPLS
  • VXLAN
Firewalls
Device Type
Policy
ACL
PBR
NAT
SNAT
MPLS VPN
IPsec VPN
GRE VPN
Pure MPLS
MPLS TE
Virtual Server
Fabricpath
Checkpoint Firewall
Checkpoint Firewall R80
Cisco ASA Firewall
Cisco Firepower NGFW
Cisco Firepower NGFW with FTD Firewall
Cisco PIX Firewall
Fortinet FortiGate Firewall
Juniper SRX Firewall
NetScreen Firewall
Palo Alto Firewall
Sidewinder Firewall
Routers
Device Type
ACL
PBR
NAT
SNAT
MPLS VPN
IPsec VPN
Pure MPLS
GRE VPN
MPLS TE
Virtual Router
Fabricpath
Policy OTV
VPLS
QoS
Alcatel Lucent Service Router
AWS DX Router
AWS Vpc Router
Cisco IOS XR
Cisco Router
Juniper Router
Versa FlexVNF
Versa Controller
Viptela vEdge
Switches
Device Type
Policy
ACL
PBR
NAT
SNAT
MPLS VPN
Pure MPLS
IPsec VPN
GRE VPN
MPLS TE
Route Table
Virtual Server
Fabricpath
OTV
VXLAN
QoS
3Com Switch
Adtran Switch
Arista Switch
Avaya Switch
Avaya VSP
Brocade Switch
Ciena Switch
Cisco ACI Leaf Switch
Cisco ACI Spine Switch
Cisco Catalyst Switch
Cisco IOS Switch
Cisco Nexus Switch
Dell Force 10 Switch
Dell Networking Switch
Dell Sonicwall
Dell PowerConnect Switch
Enterasys Switch
Extreme Switch
HP Menu-Driven Switch
HP ProCurve Switch
Juniper EX Switch
Nortel Switch
vSphere Distributed Switch
vSphere Standard Switch
Load Balancer
Device Type
Policy
ACL
PBRNATSNATMPLS VPNVirtual ServerIPsec VPNGRE VPNMPLS TEFabricpathPure MPLS
A10 Load Balancer
AWS Application Load Balancer
Cisco ACE Load Balancer
Cisco CSS Load Balancer
F5 Load Balancer
Netscaler Load Balancer
Radware Alteon Load Balancer
Information Tips:
  • See the Multiple-vendor Support List for details about a device type's basic traffic path support. If a device type is in the Tier-2 level, it means that this device type supports the basic L2 or L3 traffic path in the system.
  • For devices that the system does not recognize these special technologies as described above, you can use the traceroute function to obtain the traceroute hops and draw the path on a map with the traceroute hops.
