Key Functions
Here are the key functions provided by the NetBrain AI bot:
  • Map-related functions:
    • Draw device(s) on a map.
    • Draw the devices’ neighbors on a map.
    • Draw a path.
    • Draw an arrow from one device to another.
    • Draw a device note.
    • Display results on a map.
  • Execute CLI commands and configuration commands, extract key information from results, and detect deviations from baseline.
    • Execute the CLI command and extract key data.
    • Detect changes from baseline data.
  • Automation:
    • Execute automation.
    • Execute automation as scheduled.
    • Create a dashboard with automation results.
    • Add automation results to an existing dashboard or a map dashboard.
  • Action Plan
