Incident Triggered Dashboard
An observability dashboard will be generated for each TAF-triggered incident with their intent dashboards. All incident-triggreed intent/observability dashboards can be viewed and managed in the Incident Triggered Dashboard folder, allowing users to access incident-related results in one place.
Note: The incident-triggered intent/observability dashboards will also be deleted if the incident is deleted. |
View and Manage Incident Triggered Dashboard
- Click the start menu> Intent-Based Automation tab> Observability Dashboard> All> Incident Triggered Dashboards.
- View and manage incident-triggered intent dashboard.
- The incident-triggered intent dashboards are listed under the Intent and Universal tab. The intent dashboards are saved into folders, sorted by date.
- The incident-triggered intent dashboard can be deleted/renamed.
- View and manage incident-triggered observability dashboard.
- The observability dashboards are listed under the Observability tab.
- The observability dashboard can be deleted/renamed.
- The default observability dashboard is named Incident $Incident_ID Overview Dashboard.
- The intent dashboards related to the same incident will be added to a Triggered Automation dashboard group by default.
