R12.1 Project-2025Sep08
CLI Command Template
The system offers several built-in CLI templates to bulk add CLI commands to your tasks and allows you to create your own templates. Inside a template, you can define the applicable device types for each CLI command as qualifications. Then, by loading a CLI template into your tasks, such as Runbook, Benchmark and so on, you can leverage the predefined qualifications to exclude improper commands from the execution scope.
The main topics include:
