Import and Export CLI Commands Template
Import CLI Commands Template
Click
on the right of the folder’s name and select Import Template. Currently, we support the XCT file for CLI Commands Template import.
You can add multiple templates at one time.
Export CLI Commands template
To export all CLI Commands Template in a folder, click
on the right of the folder’s name and select Export Template. The exported file will be a zip file if the folder contains more than 1 template.
To export a single CLI Commands Template, click
on the right of the template’s name, and select Export. The exported file will be an XCT file.
Two functions to leverage CLI Command Template
The CLI command tempates can be applied to operations such as creating Runbook CLI Command Node, scheduling a Benchmark Task. During these processes, you cn select multiple CLI command templates from the Load Template dialog box.
- From Execute CLI Node in Runbook:
From Benchmark:
Related Topics:
