Highlight a Map
On a map, you can run Qapps to highlight devices and interfaces to check network problems or make your network configuration displayed intuitively.
The following table lists the network technologies you can highlight by running related Qapps on a map (all these Qapps are the built-in Qapps. You can search the Qapp by name in the Select Qapp window).
Table 1: Network Technology Highlighted by Running Qapps on a Map
Network TechnologyQapp NameDescription
OSPFCheck Access List on OSPF LinkCheck and highlight the OSPF interface configured with ACL.
Check OSPF Corrupt PacketCheck and highlight devices without the BAD LSA log.
Check OSPF AuthenticationCheck and highlight neighboring interfaces without authentication configured.
Check OSPF Link MTUCheck and highlight OSPF MTU on neighboring interfaces.
Check OSPF Link PriorityCheck and highlight OSPF interface priority on neighboring interfaces.
Check OSPF Network TypeCheck and highlight the interface network type on OSPF neighboring interfaces.
Verify HELLO Packets Sent Out of InterfaceVerify and highlight HELLO packets sent or received normally.
Verify HELLO Parameters MatchVerify and highlight OSPF neighboring devices with mismatched parameters.
ACLHighlight Specified ACLCheck the ACL name and draw it on the Map.
BGPHighlight BGPHighlight the BGP configuration, AS, neighbors, and summary.
EIGRPHighlight EIGRP ConfigurationHighlight the EIGRP configuration and AS number.
ISISCheck ISIS SPF-LogCheck and highlight devices with the ISIS SPF log.
MPLSHighlight MPLSHighlight MPLS configuration, interface, and VRF.
Per-VLAN Spanning Tree (PVST)Highlight PVSTHighlight PVST topology information.
Highlight PVST ConfigurationHighlight PVST configuration.
Highlight Switchport ModeHighlight the switch port mode.
Highlight Spanning-Tree FeaturesHighlight spanning-tree features.
SNMPHighlight SNMP CommunityCheck and highlight the SNMP community with ACL configured.
Highlight SNMP Group VersionHighlight the SNMP group version and security model.
Highlight SNMP TrapsHighlight SNMP traps and display related information.
MulticastHighlight Shared TreeHighlight roles and configuration in the shared tree.
Highlight Source TreeHighlight roles and configuration in the source tree.
VLANHighlight Specified VLANHighlight the interfaces in the specified VLAN.
Highlight VLANHighlight the switch trunk port and the VLAN access port.
Check VLAN Allowed on Trunk PortHighlight the VLANs allowed on a trunk port.
QoSHighlight QoS Configuration along the PathHighlight QoS configuration.
Highlight QoS Interface Queuing StrategyHighlight the QoS interface queuing strategy.
Routing protocolHighlight Routing ProtocolHighlight devices and interfaces about routing protocol configuration.
Static routingHighlight StaticHighlight devices and interfaces with static routing configured.
VRFHighlight Specified VRFHighlight the interfaces in a specific VRF.
Interface speed and duplexCheck Neighboring Interface Speed and DuplexCheck and highlight neighboring interfaces with speed or duplex mismatched.
Interface MTUHighlight Interface MTUHighlight the interface MTU.
Neighboring port modeCheck Neighboring Port ModeCheck and highlight neighboring ports with the mismatched port mode.
Interface ruleCheck Interface RuleCheck and highlight the interfaces whose status is down and the interface description is not null.
RedistributionHighlight RedistributionHighlight the redistribution configuration.
