Save a Map
An asterisk (*) next to a map name indicates that there are unsaved changes.
Follow the steps to save a map:
  1. On the Map toolbar, select the icon (you can also press Ctrl+S).
  2. If you do not have editing rights for the map, do one of the following:
    • When prompted, select Yes to save the map as a new copy.
    • Alternatively, select Map > Save As to save a new map.
      Information Note: Some elements, such as data views and runbooks, may not be saved in the new map.
  3. Select a folder and enter a name for the map. Maps saved in Private or Desktop are visible only to you. To make a map available to all users, save it under Public.
  4. Select OK.
    The map is now saved and appears in the Files pane.
    Information Tip: Refer to Manage Map Data  for details about the data you can save in a map file.
