Golden Engineering Studio
Golden Engineering Studio (GES) helps users to maintain consistent design and prevent configuration drifts to avoid security vulnerabilities, compliance issues, and outages across the network. With GES, users can discover the network design (Golden Config) by reverse engineering and create thousands of automations without any code. It includes the following main components:
  • Golden Config: Defining, discovering, managing, and verifying the network design. It uses two methods, reverse engineering and forward engineering, to discover the Golden config design in your network.
  • Golden Feature: Model the critical design assets for your network, which can be used as the base to further build the intent automation (Golden Intent).
  • Golden Intent: Simplify the creation process of member intents for Golden Features so that users do not need to learn multiple concepts and the complex logic of NI and ADT, reducing the learning curve.
  • Golden Assessment: The Golden Assessment feature streamlines the process of discovering the network features and corresponding Golden Config by reducing reverse engineering time for all features. It standardizes configuration processes, improves accuracy, and helps network teams work more efficiently by automating feature discovery (reference device) and implementation across the infrastructure.
