R12.1 Project-2025/11/05
Export Response
- On the Export window, define the export settings.
- Select a Word style.
- Input the Title, Subtitle, Author, and Abstract.
- Click Export.
- After the document is successfully generated, select your next step on the Export window.
- Download: Download it to your local drive.
- Save to File: Save it as a NetBrain file.
- AI Document: Go to the AI Document to edit it before saving.
