Discover NSX-V Network in NetBrain
Before visualizing an NSX-V network, first discover the network data model in a NetBrain domain, including NSX Managers, NSX Controllers, Logical Switches, Distributed Logical Routers, and NSX Edges.
Note: An NSX Manager is registered with a vCenter system. The corresponding vCenter Controller must be discovered before discovering the NSX-V Manager. See Discover vCenter Data in NetBrain for more details. |
- In the Domain Management page, select Discover.
- Click Select API Servers and select NSX that you have configured.
- Click Start Discovery.
Note: If the URL of the NSX Manager entered in the Endpoints field contains a domain name, you must enter the domain name here for discovery.
Note: The discovery for your NSX-V network only retrieves basic data. After the discovery, you need to execute a benchmark task to retrieve all data and build all components, including visual spaces and data views. See Auto-Update NSX-V Data in NetBrain through Benchmark for details.
