R12.1-2025July30
Diagnosis Type for Intent Definition
The following table lists 8 types of diagnoses for intent definition:
Diagnosis Type
Description
Sample
Config Diagnosis
Define a config diagnosis based on the device configuration.
CLI Diagnosis
Define a CLI diagnosis based on the CLI commands.
SNMP Diagnosis
Define a SNMP diagnosis using SNMP OID through three methods: SNMPGet, SNMPWalk, and SNMPTable.
API Diagnosis
Define a API diagnosis to enable the diagnosis of SDN/Cloud Network and SPOG Data View from an external system via REST API (such as Splunk, SolarWinds, and ServiceNow).
Ping Diagnosis
Define a Ping/Trace diagnosis to diagnose device connectivity, which can ping and trace to the current device via front server respectively.
Trace Diagnosis
Device Diagnosis Block
Define a device diagnosis block without SNMP/CLI/Config/API command.
Intent Diagnosis Block
Add an intent diagnosis block with only the device-independent logic.
