Logo
R12.1-2025June05
Connect to a Device with Smart CLI
You can connect to network devices with Smart CLI and execute CLI commands to view the command outputs in the Smart CLI window.
Use the Smart CLI through either of the following entries:
  • Connect to a Device from a NetBrain Map
  • Connect to a Device from Smart CLI Window
Install Smart CLI on Ubuntu Connect to a Device from NetBrain Map
