Automation Data Table (ADT)
Automation Data Table (ADT) is an extended global data table for managing the critical network assets and network intents associated with those network assets. ADT is designed to provide users with two capabilities:
  • Use ADT to build, organize and share intents across the network: Customize more network automation assets in Automation Data Table Manager, such as critical Application and Path, critical WAN Link, critical Device Failover, critical Subnet, and critical Route, then associate intents and diagnosis result for troubleshooting network problem.
  • ADT is a database for intents, supporting intent creation and replication. The system provides two methods (Base Table and Column Group) in Automation Data Table Builder to build the basic table data and create and bind the intent for each automation asset.
The following diagram illustrates how an ADT looks like. See Key Components of Automation Data Table for more details.
The following diagram illustrates how to create Automation Data Table.
