Operations in AI Bot
Privilege/Requirement
PA License
Retrieve live data from the device
Via CLI command
Config file
Access to Live Network privilege
Access granted based on the defined Device Access Policy
The issued CLI commands comply with the Rules for CLI Command Data Retrieval in the system management
Does not require a PA license.
Execute Network Intent
The Run Network Intent privilege in the role.
Usage limits for users without the PA license:
- During one back-and-forth interaction, if a user performs troubleshooting by manually running intents, the number of intents is limited to 24.
During one back-and-forth interaction, a user is allowed to create a scheduled task for only one home intent.
During one back-and-forth interaction, a user without a PA license cannot create a scheduled task for any intent in an ADT (automation data table).
Open AI Bot Manager
AI Bot Management privilege.
Note: Open CLI dictionary and config dictionary do not require this privilege. These roles include the privilege by default:
Domain Admin
Power User
Network Change Creator
Network Change Approver
