Add to Observability Dashboard
Creating an observability dashboard is smoother when you directly add the newly created intent dashboard to an observability dashboard. When you successfully create an intent dashboard, you will get the option to add it directly to an observability dashboard as follows:
Alternatively, you can add the current intent dashboard to an existing or a new observability dashboard from the view mode as follows:
In the Add to Observability Dashboard window, you can:
Add to an Existing Observability Dashboard
  1. Select Existing Dashboard.
  2. Dashboard Name: Select an existing observability dashboard.
  3. Chart Name. Add the intent dashboard to an existing or new chart.
    • Select an existing dashboard group.
    •   If none of the existing charts are suitable, add them to a new chart instead.
      In the
      New Dashboard Group window, enter the dashboard group title, which is also the result detail chart title.
    • Users can select multiple dashboard groups.
Create a New Observability Dashboard
  1. Select New Dashboard.
  2. Enter the dashboard name.
  3. Select the location to store the new observability dashboard.
  4. Enter the dashboard group title, which is also the result detail chart title.
  5. Click OK.
  6. In the Add to Observability Dashboard window,
    • Click Close to close the current window.
    • Click Open Observability Dashboard to open and edit the newly created observability dashboard, or view the results.
