R12.1-2025July30
Access the Documented Path via A/B Dialog
When you search for an A/B path, any existing pre-documented path with the same source and destination appears in the intelligence dialog. You can view the results of the pre-documented path and generate its path map from this dialog.
- On the search bar, click the path icon
- Enter the source and the destination IP addresses (device hostnames or DNS names).
- Select the required path.
