R12.1-2025July30
AAM License Extension for Running Path NI
To access the full functionality of the application path feature, an AAM module license is required.
You can execute unlimited path intents without a PA license.
  • When path intents are verified and executed in AAM, the PA license nodes will not be counted to occupy the PA license quota.
  • PA license quota will not be counted when path intents are executed from any entrances in the system. The following table lists the details.
Run Path Intent EntrancesCount PA license
Path Intent Pane and Pop-out Path Intent Dialog×
Runbook Intent Node×
Preventive Automation×
TAF triggers NI or NIC×
