What Content Will Be Saved into Runbook Template
The following content will be saved into the RBT.
ContentDescription
Map for templateA runbook can only be instantiated based on a map; therefore, the RBT can be associated with a specific map. Users can either use the default map or modify it to another map.
Reference Runbook
Each RBT stores a reference runbook, which is displayed during editing to ensure the RBT and runbook editing UIs remain consistent.
The RBT stores template variables that are used to replace certain parameters from the reference runbook, achieving the templating purpose.
Template Settings by NodeRefers to the fixed parameter settings for each node in the runbook.
Template Variable
  • Settings that need to be parameterized after the runbook is converted into RBT. These settings will be converted into template variables.
  • Variables used as input for the template, such as the command with variables in the ‘Execution CLI Command’: show ip interface $intf.
