Visualize Azure Network
Prerequisites
Discover your Azure Network in NetworkBrain. For more details, refer to NetworkBrain Quick Setup Guide_Azure.
User Flow
The general user flow of visualizing an Azure network in NetworkBrain is as follows:
- Understand Azure Network Tree
- Calculate Path Across Azure Network
- Build Data View Template to View More Azure Data
- Use Runbook Automation for Azure Network
- Integrate with Third-party Tools for SPOG
For more details about Azure network objects that can be visualized, refer to Supported Azure Network Objects.
