View Ticket Types
View ticket types and their knowledge documents and prompts.
- View the ticket types generated by the LLM.
- View the ticket fields for each ticket type. You can click it to view the details, as well as the original ticket.
- (If needed) You can adjust the prompt and re-generate the ticket types, knowledge documents and prompts.
- View the knowledge document summarized by AI. You can modify the troubleshooting steps as needed.
- View the AI Insight Prompt generated by AI. It might contain variables.
