View Golden Intent and ADT Intent
The Automation Insight tab groups these intents by seed NI and displays one intent column in each row.
Example: View golden intent BGP Config Change.
- It belongs to the category of General.
- The last execution time was Feb 10, 2025. When there are multiple NIs, it displays the latest update time of all NIs.
- Devices. The total number of distinct devices in all NIs was 3. Click 3 to view the devices.
- Results. The last result contained 3 success status code counts. which included device status code count and intent status code count. Click 3 to open the tooltip. (Refer to View Common Intents for more details.)
- History. The last execution result had a success status, but the historical results contained at least one alert. Click the icon to open the tooltip. In the tooltip, you can switch between different intents to view its trend chart. (Refer to View Common Intents section for more details.)
