View Common Intent
The Automation Insight tab displays the last results of common intents.
Example: View the common intent BGP Neighbor Check.
- It belongs to the category of Routing. (The category can be defined in Insight Manager).
- The last execution time was Dec 01, 2024.
- Devices. There were 2 devices in the last execution result of the NI. Click 2 and view the devices.
- Results. The last result contained 3 alert status code counts, which included device status code count and intent alert status code count.
- Click 3 to open the tooltip to view the alert messages.
- In the tooltip, you can see more details.
- Click the alert US-BOS-R1: BGP Neighbor… to open the Diagnosis Details and Compare window.
- Click BGP Neighbor Check to open the detail pane.
- Click 3 to open the Diagnosis Message window.
- History. The last execution result had alerts.
- Click
to open the tooltip and click the time points to view its execution results in the detail pane.
- Understand its icons.
Icon Indication The last execution result had alerts. The history results contain no alerts. The last execution result had a success status, but the historical results contained at least one alert.
- Click
