Use Prompt Node
You can leverage the prompt node to organize bot conversation flow by grouping automations.
  1. Drag and drop the prompt node to the flowchart.
  2. Double-click the node to rename it.
Power User in Editor
End User in Chat Console
Example:  To execute the L2 General Check intent,
End User: Click Daily Check > L2 General Check
