Manage Chatbot
Click the start menu and select Intent-Based Automation > Chatbot Manager.
You can manage bots in the Chatbot Manager.
View Mode
- Browse and view existing bot user flows
- Save as, import, or export a bot
- Delete, rename, or move the bot to different folders
- Enable/disable a bot
Check the usage of the bot.
Edit Mode
In the Chatbot Manager, click Edit.
Lock/unlock a bot with
to avoid unauthorized modification.
Control which user roles can access this bot, and whether to allow the session feature and show flowchart command in the end user chat console interface.
