Use Case 2: Retrieve Data from ADT
After an ADT view is added to TAF Lite, any cell data can be retrieved and returned to the 3rd-part system via API call.
API Parameters
To locate and retrieve data from a specific cell, the API is required to include a column name and a rule to filter out row names.
Information Tip: If no rule is defined to filter out the rows, data from all rows in the column will be returned to the 3rd-party system.
  • API URL: API/V3/TAF/Lite/adt/data
  • Description: The API is for retrieving ADT data.
  • Input Parameters:
    Parameter Type Required Description
    endpoint string Yes The endpoint generated by the system when users add an ADT view to TAF Lite.
    passKey string Yes To authenticate the access to the ADT view.
    filterDevices array No
    A list of device names to filter out rows in the ADT view.
    Define a list of device names. A row matches if the device name in the device column is in the list.
    columns array No
    To define the returned columns, users need to fill in the display name list for the column.
    When the value is empty, all columns will be returned.
  • Optional Parameters for Advanced Settings
    option.rowFilter object No
    columnName: value
    Multiple values are combined using AND logic.
    pageSize int No The count of returned entries. The default value is 100.
    pageNumber int No The count of returned pages. The default value is 1.
Sample Request:
A computer screen shot of a code  Description automatically generated
Response
The table includes what data can be retrieved by API and how the data will be returned.
ADT Column Type Return
device
  • device name
device list
device name1
device name2
interface device - interface name
A screenshot of a computer  Description automatically generated
interface list
device - interface name1
device - interface name2
string string
int string
float string
bool string (True/False)
map
  • map id
  • map name
  • map url
time 4/25/2024 10:00:13 PM, UTC 5
intent
  • intent name
  • intent id
intent result summary
(m) alert, (n) success
intent status code summary
1st message | number
path
  • application name
  • path id
  • path name
site
  • site id
  • site name
  • site full path
  • site map url
ADT Dataset [device], [cmd list/config], [timestamp]
