Search for Maps
- Enter one of the following search terms in the search bar:
- Map name
- Map page name
- Device hostname or management IP address
- Interface name or IP address
- Map note
- Press the Enter key on your keyboard to start searching. The search results are displayed with the matched keyword highlighted.
Note: The list includes various maps, but only the "common map" supports searching. For the rest of the maps in the list, users cannot perform searches within them to find specific information.
- Point to a map result and then click the
icon and select Preview to preview the map.
Tip: You can open the map by either clicking the "Map" button or selecting "Open" from the dropdown menu .
Tip: To share the map, point to the map entry and click the icon to select Share.
