Open Source ADT
When the ADT intent column is created by the Intent Templates from Other ADT method, users can open the source ADT that is used as data source for creating the ADT intent column.
Follow the steps to check the Source ADT that provides seed intents for creating the ADT Intent column.
- Place your cursor over the Intent column and click
. - Click Open Source ADT in the menu, then the ADT Manager will open with the Source ADT displayed.
