NI Remediation with Intent Node for Change Verification
Intent node can support 5 kinds of intents: Auto Intent, Golden Intent, ADT Intent, Intent Template, and Standalone Intent. This enables you to use the intent node in the Change Management Runbook Template for change verification. Consequently, integration with the intent node in NI remediation is also allowed.
The items listed in the Network Intent area are retrieved from the Change Management Runbook Template. By displaying these items, you can assign values to NIT's macro variables or NI's task variables using NI variable values.
The items include:
- Auto Intent and Intent Template
- Task Variables from Standalone Intent, Golden Intent, or ADT Intent
Note: These inputs are merged into a single item for users to assign values.
