Incident Triggered Dashboard
An observability dashboard will be generated for each TAF-triggered incident with their intent dashboards. All incident-triggreed intent/observability dashboards can be viewed and managed in the Incident Triggered Dashboard folder, allowing users to access incident-related results in one place.
Information Note: The incident-triggered intent/observability dashboards will also be deleted if the incident is deleted.
View and Manage Incident Triggered Dashboard
  1. Click the start menu> Intent-Based Automation tab> Observability Dashboard> All> Incident Triggered Dashboards.
  2. View and manage incident-triggered intent dashboard.
    • The incident-triggered intent dashboards are listed under the Intent and Universal tab. The intent dashboards are saved into folders, sorted by date.
    • The incident-triggered intent dashboard can be deleted/renamed.
  3. View and manage incident-triggered observability dashboard.
    • The observability dashboards are listed under the Observability tab.
    • The observability dashboard can be deleted/renamed.
    • The default observability dashboard is named Incident $Incident_ID Overview Dashboard.
    • The intent dashboards related to the same incident will be added to a Triggered Automation dashboard group by default.
