Golden Intent Builder
Golden Intent is designed to simplify the creation of member intents for related feature instances. This approach eliminates the need to understand multiple concepts and the complex logic of NI and ADT. Thereby, reduces the learning costs.
Customer Value
After discovering the features configured on the device in the system and generating a feature instance table based on the feature discovery function, users can associate one or more golden intents for each device list and feature for diagnosis analysis. Furthermore, it can be integrated with PAF, TAF, Bot, and dashboard automation flow, providing greater value for automation.
The workflow of the entire GES and where the golden intent builder is located are as follows:
Key Functions of Golden Intent
The Golden Intent tab can be divided into four areas:
- Left Pane: It can be regarded as a golden intent manager, and you can manage golden intents here.
Header: Used to display the key information at the golden intent level and provides the major intent-level operations.
Also, you can switch between three modes: Define, Build, and Publish. - Flowchart: Define and complete the entire golden intent definition.
- Property Pane: When users select different nodes, the corresponding information or configuration interface will be displayed on the property pane.
The steps required to create a golden intent are shown in the below chart:
