Follow-up Intent Template Settings
The key settings of follow-up intent template is as follows:
    Replicate Follow-up Intent Template to:
    You can replicate the follow-up intent template to:
    • This Device’s Neighbor, IPv4 L3 Neighbor, IPv6 L3 Neighbor, and L2 Neighbor can be selected.
    • Device by Variable, the range of variables that can be selected includes:
      • $this_device
      • Intent Variables under Calling Intent
      • Macro Variables under Calling Intent
      • Variables from Automation Data Table
      • Task Variables
      • Variable from Golden Neighbor Table
    Moreover, the system supports converting IP address to device hostname when the corresponding intent is applied.
    Set Macro Variables of Follow-up Intent Template:
    Assign a value to each macro variable defined in the follow-up NIT. The range of variables that can be selected is the same as the Device by Variable in Replicate Device Scope.
    Other Settings
    • Follow-up Execution Settings: Define the following settings for the current intent.
    • Merge multiple replicated intents into one: This check box is not selected by default, which indicates each device generates an intent.
    • Set Device Key for Selected Table: Set the device key to match table variable values precisely.
    For example, replicate the current intent to R1. A variable value is set to target_subnet of the following table:
    If no key is defined, all three values will be passed to R1.
    If column “Device” is set as key, only 10.10.2.3/16 will be passed to R1.
    • Draw Arrow from This Device to Next: Draw an arrow directly from the current device to the next device whose intent is to be replicated.
      An arrow example on a map:
    • Annotation for Diagnosis Tree: Annotations are displayed on the line of diagnosis tree.
