Execute a Benchmark Task
There are two ways to execute a Benchmark task:
Schedule the Benchmark Task
  1. Right-click on the target Benchmark task and select 'Edit' in the drop-down menu.
  2. In the Edit Benchmark Task window, set up the frequency for Benchmark on the Frequency tab.
  3. Set up the device scope, retrieve live data, CLI commands, additional operations after Benchmark and plugins for Benchmark. See Setup a Benchmark Task for details.
  4. Check the Enable box before the target Benchmark task.
Manually Execute the Task
Right-click on the target Benchmark task and select Run Now in the drop-down menu.
