Device Type
Device Type refers to a group of devices categorized by the operating system for centralized management. Devices with the same or similar operating system versions are defined as one device type to share the same supported feature set.
Add a Device Type
- Log in to Tenant Management Page.
- In the Tenant Management page, click the
icon in the upper-left corner and select Multi-vendor Support.
- Use either of the following ways to add a new device type.
Tip: To browse the supported operations for a specific device type, you can double-click an entry. |
Add entries manually
Import a .csv file
