Device Properties
Both built-in and customized device properties are stored in the Global Data Repository. You can browse, modify, and export device properties from the Device Details pane.
Edit a Device Property Value
- In the Device Details pane, click the Properties tab. The device properties are listed by default.
Click the
icon to open the option for editing properties in a new window.
Click the
icon to open the property fields in editable mode.
- Modify the required values and click Save.
Tip: The customization for the property value can also be performed by running a Qapp. See Creating a Qapp to Retrieve Customized Device Property Value for more details. Note: If the Manual Editing attribute of the property is disabled, its value cannot be customized in the Device Details pane. Tip: To disable the editing right for any user, please remove the user privilege Shared Resource and File Management from the user.
