Built-in Device Properties
The following table lists the device properties/attributes (case-sensitive).
Property/Attribute Name | Display Name in Device Details Pane | Description |
name | Hostname | The hostname of a device. |
mgmtIP | Mgmt IP | The management IP of a device. |
subTypeName | Device Type | The device type of a device. |
mgmtIntf | Mgmt Interface | The management interface of a device. |
vendor | Vendor | The vendor information about a device. |
model | Model | The model information about a device. |
ver | Software Version | The version of a device. |
sn | Serial Number | The serial number of a device. |
site | Site | The site that a device belongs to. |
loc | Location | The location of a device. |
contact | Contact | The contact person of a device. |
mem | System Memory Size | The system memory size of a device. |
assetTag | Asset Tag | The asset tag of a device. |
layer | Hierarchy Layer | The network layer that a device belongs to. |
descr | Description | The description of a device. |
oid | sysObjectID | The system object ID of a device. |
driverName | Driver | The driver that a device uses. |
assignTags | Layout Tag | The tag assigned to a device for applying the network-based layout style on a map. |
hasBGPConfig | BGP Enabling | Indicate whether a device has been configured with the BGP protocol. |
hasOSPFConfig | OSPF Enabling | Indicate whether a device has been configured with the OSPF protocol. |
hasEIGRPConfig | EIGRP Enabling | Indicate whether a device has been configured with the EIGRP protocol. |
hasISISConfig | IS-IS Enabling | Indicate whether a device has been configured with the IS-IS protocol. |
hasMulticastConfig | Multicast Enabling | Indicate whether a device has been configured with the Multicast protocol. |
mgmtMAC | Management MAC | The management MAC of a device. |
lwap_defaultGW | Default Gateway | The default gateway of an LWAP device. |
lwap_group | Group | The group that an LWAP device belongs to. |
lwap_priCntrllr | Primary Controller | The primary controller of an LWAP device. |
lwap_secCntrllr | Second Controller | The second controller of an LWAP device. |
