Default Data Source Settings
The Default Data Source for Automation at domain level is configured in Domain Management (Advanced Settings). When enabled, it can have essential impact on the data source settings in applicable functions (for more information, see Apply Default Data Source to AutomationSpecify Data Source for Building ADT Columns). By default, the default data source for automation is disabled. When creating dataset via Import File Wizard, the created dataset can be set as the default data source in domain, and the settings can be synced to the default data source settings in Domain Management (Advanced Settings) (for more information, see Set Default Data Source in Import File Wizard).
